Verizon Treo 650 any hope?
I just saw the A6 Avant / Treo 650 announcement and read the fine print that it is for GSM phones only. If people can answer the following questions that would be great:
Does the Verizon 650 work with a 2005 A6 MMI at all? Or does it work, but just not as well?
The announcement mentioned a cradle being available this fall. Will it work with a Treo 600? Will there still be verizon limitations?
Thanks,
Jeff
Thanks,
Jeff
It works as well as any other Verizon BT phone. In other words, you can't get contacts on the MMI from the phone.
I think the Verizon BT Blackberry is the same way, but haven't tested it to find out.
sgroer
12-08-2007 12:50 PM
