What is this??
Cam position sensor. There's a left and a right. Are you worrying about it?
Welcome aboard, Rj !
The car is an 06 a6 and has a little over 80k miles. The CEL came on and I have the codes pasted below. I wanted to confirm that pic is sensor g163 (cam sensor) as I'm hoping that the cam sensor I pointed to in the pic is the culprit and not a timing issue. Any opinions on the codes?? I figured the sensor is only $60 and if that is in fact the correct sensor its as easy as it gets to replace. Might just replace that anyway and hope the code stays off. Any input is appreciated! Thanks for the quick reply.
000838 - Camshaft Position Sensor (G163)
P0346 - 006 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 134767 km
Time Indication: 0
Date: 2016.06.23
Time: 20:05:04
Freeze Frame:
RPM: 1056 /min
Mass Air / Rev.: 98.1 mg/str
Temperature: 94.5°C
Idle
Bin. Bits: 00010000
Speed: 23.0 km/h
000033 - Bank 2: Camshaft A (Intake)
P0021 - 008 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 134779 km
Time Indication: 0
Date: 2016.06.24
Time: 07:22:05
Freeze Frame:
RPM: 2336 /min
Mass Air / Rev.: 414.2 mg/str
Temperature: 91.5°C
Part Throttle
Bin. Bits: 00000000
Steering Angle: 126.92°
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 40
Mileage: 134767 km
Time Indication: 0
Date: 2016.06.23
Time: 20:05:04
Freeze Frame:
RPM: 1056 /min
Temperature: 94.5°C
Idle
Bin. Bits: 00010000
Speed: 23.0 km/h
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 134779 km
Time Indication: 0
Date: 2016.06.24
Time: 07:22:05
Freeze Frame:
RPM: 2336 /min
Temperature: 91.5°C
Part Throttle
Bin. Bits: 00000000
sillverchevy
Want To Buy - Archive (NO NEW POSTS HERE)
04-01-2016 06:26 PM
stewarbd
01-07-2009 03:29 AM
