Last edit by: IB Advertising
- Audi A6 C6 Lowering Modificaitons and How to Install Lowering Kit<br>Overview of popular modifications to customize your Audi A6 C6.
What is the best way to drop (lower)?
Hello all,
I just bought my Audi A6 with 19" CEC Style c859 wheels. The car looks a bit high off the ground. The car would look perfect if it was about 1" to 2" lower. So what is the best why to drop the car? Would like to keep the ride feel as much as possible.
Thanks for your time and help,
Nick
Nick
umm... using springs.
I have Koni FSD shocks and Eibach springs. I was considering get the H&R springs, but then decided to change the shocks as well.
What are the best manufacts for springs and shocks?
I have been reading and reading and it seemed that Coilovers were my answer to lowering my car. I just want to go down an inch or so. But looking harder, it seems that there is no options for coilovers for a 2006 A6? Is that correct?
If so, What spring and shock should I use to lower an inch?
I will post a Pic of my car soon.
thanks for your time and help,
Nick
Nick
There are plenty of options for the A6. I'd go with KW brand coilovers. Look for KW Variant 1 or V1 on ebay or other sites.
Never visited this site before, but I found a kit on there: http://www.uniqueeurodesign.com/Prod...tCode=10210049
Is the a place i can go to see the different options for A6 C6?
Nick
Hi Nick, I sure am- they're made by Bagyard Airride out of Austria. They're OEM Application-Specific Bilstein Shocks that have been shortened, inverted and then mated to airbags. Even with large wheels and thin tires, the ride is wonderful. Airride is a good option, but you're looking at a pretty involved installation.
The basic makeup of the system is:
Compressors x2 (to fill the tank)
Water Traps (to keep moisture out)
7-gallon Tank (gives me two full lifts of the car before compressors kick on)
8-way manifold (to raise/lower)
Switchbox (controls height)
Air Gauge (to check rideheight)
Airbags
I use an accuair manifold, which is part of the e-level system. It allows you 3 preset heights as well as all down, and all up. It's a position-based rideheight managment system so it will self adjust to keep the car level.
http://www.accuaircs.com/product_elevel.html
Here's a small write-up on Bagyard, and their passion for airride.
http://forums.vwvortex.com/zerothread?id=4480915
Airbags
The more i read the more quesions i get. Does any one use Struts on their A6? Is that even an option i can look at?
Thanks for all your time and help,
Nick
Nick
KWv1 or KWv3 or HR are coilover options... maybe PSS9's are out for the C6 by now...
but i think your best bet would be Koni FSD shocks/strunts and Eibach springs. this is the cheapest way to go.
problem with coilovers is that in the rear you have to take out the entire coilover to make any height adjustments... thus defeats the point of adjustable coilovers with them on the car... but i like my KWv3s for their ride quality but others will stand by the koni/eibach setup
I would really like to know this difference by looking at the insides of both a shock or strut. I have read the difference, but can not visualize the difference.
Thanks,
Nick
