what problems can i run into running a 275/30 tire on a 19x8 rim?
i have run 255/35 tires for the past 2.5 years without issues however i wanted to go to a 275/30 tire. Is the tire too wide for a 19x8 rim?
i looked up a tire size calculator and the difference in actual speed/speedometer speed is minimal thus a moot point. My question is strictly what can happen if i run a wider tire 2cm=0.78in
thanks
thanks
thanks
thanks
A 275 tire is 10.94 inches wide. If you put that tire on a rim that is only 8 inches wide you are going to have a safety issue. The widest tire you can safely put on an 8 inch rim is a 255.
Kevin makes a good point. You end up piching the sidewalls of the tire thus causing the tire to bulge up in the center....(think motorcycle tires) thus nagating the purpose of adding a wider tire. You will in all actuality end up having a SMALLER contact patch on the ground.
I saw your lovely Bordeaux car. What wheels do you have ? I mean J, R, ET? What rubber sizes should you have been shoeing your rims?
Tks
I run a 19x8.5 wheel with a 35mm offset and I run a 245 tire. As far as what size tire you should run on your rims....well it all depends on how wide the rim is. Each tire has a spec on what the rim width should be.
redrocker55
S4 (B8 Platform) Discussion
03-02-2011 10:50 AM
xpl0sive
11-21-2008 10:34 AM
B56
09-22-2008 12:19 PM
Audilard
Wheels & Tires Discussion
04-05-2007 02:02 PM
AC S4
04-21-2003 11:52 AM
