What should I replace my original ContiProContact all-seasons with?
My almost 3-yr-old '05 A6 4.2's original all-seasons (245/45HR17) are nearly done, so I'm thinking of replacing them before winter. The Conti's, which are XL rated, are in "grand touring" class.
1. MUST I replace them with the same or another XL rated tire and, if so, which ones should I consider (preferably in the "high peformance" class, if any)?
2. If it's safe for me to use a non-XL rated tire, I'd like to use a "high performance" all-season. In that case, which should I consider?
Thanks for any advice you can give me!!
I just went through all this. You will get a huge variety of answers. Most people in the All-Season category put on Bridgestone Potenza A960. You cannot go wrong with those. Some put Michelin's - some did not like them, some loved them. A few put on Pirelli's. I just shod my ride with Goodyear Eagle F1 All-Season tires. There were very few reviews on this tire but I had my reasons:
1.) Carbon fiber reinforced sidewalls.
2.) Goodyear reputation.
3.) Recommendation by a person who drove these back to back against Bridgestones.
4.) Excellent wet weather rating.
5.) Protective edge that shields the rim against curb-rash.
6.) Very square outer corners - incredibly stable driving.
They are everything I expected - the car guides like it is on rails (wet or dry).
Caution: The side walls are a bit stiff so warn the installer not to pry on your expensive rims. Use air pressure instead (and take cover!) It's exciting.
No regrets here!
John
No regrets here!
John
I'd buy the Goodyear F-1's in a heartbeat, but they don't come in 245/45 X 17. I opted for 17" OEM wheels w/all-seasons, since I only use them
4-5 months a year. My Spring thru Fall wheels are BBS 18"ers with Michelin Pilot Sport PS2's.
Both cost a fortune, but well worth it.
Are the 18" Goodyear F-1's you got XL rated?
How important is it that I stick with an XL rated tire?
Thanks for any more input you can give me.
I don't know what XL means in the tire world but Z is the highest speed rating you can get. And, yes, they do come in 245/45-17.
Good luck
John
Good luck
John
You're right!! I just didn't go far enough on Tirerack's 4 pages of all-seasons in my size.
Thanks, again.
Thanks, again.
<ul><li><a href="http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35">me thinks so</a></li></ul>
I spoke with Gary Stanley at Tirerak early this morning. He told me that, in a 45 profile tire, any of the UHP all-seasons on Tirerack's 4 pages
would be OK, i.e., an XL load rated tire was not necessary, since all the non-XL load rated tires could handle all the weight I might conceivably
have at any time on an '05 A6 4.2 sedan.
