wheel damage by tire shop, advice?
I know this probably belongs on a general forum, but I knew I would get more responses here as I need to address this soon.
I dropped my Audi off to have the original full size spare 19" RS wheel mounted and replace a scratched wheel, with tire swap.
So I get the car home and I find that the original spare (new, with sticker glue still on it) had been damaged in mounting and then moved to a different corner to hide the damage.
The tire shop admitted that they had made the mistake, and my question is this:
The tire was essentially new. I feel that it should be replaced for this reason. The shop will repair the wheel, the damage is minor, and I am sure it will look like new once this is done.
Having said that, for both parties: what is the RIGHT thing to do here?
-K
p.s. damage is minor, a two inch gash on the wheel edge, cosmetic only. I have three repaired wheels that look like new on the car now and am generally satisfied with this approach, but right is right, so what do you think?
-K
Wait... what was damaged, the rim or the tire? You started talking about a rim, then the tire, and then finished talking about the rim again.
First, you have it easy that the shop admitted to the issue.
If rim is damaged, then I think easiest approach would be to get the rim refinished. Not sure if you will be able to convince them to get you a new rim.
If tire is damaged, then you need to have the tire replaced. You don't want to be riding on a damaged/repaired rubber.
-K
-K
ohbw
12
09-16-2006 02:07 AM
rdynamix
12
06-20-2005 10:02 AM
mzancz
Wheels & Tires Discussion
05-18-2004 09:33 AM
davidjuw
9
10-08-2000 07:59 PM
