Who has a TSBs on lagging transmission and long crank times
#11
I have an '05 A5 3.2 I bought in Dec. '06 with 10K miles on it at the time. Ever since I got the car I've had occasional long cranking where the engine doesn't fire and sometimes the cranking just times out without the engine starting. Can happen cold or warm, but seems to happen most often when the engine is restarted after sitting for a couple of hours, moreso than when it sits overnight. The car usually just fires up on the second attempt. I've also found that if I push on the accelerator while cranking, the engine immediately fires.
Dealer has tried numerous fixes, and the TSBs, but never been able to fix it. I've proposed to the dealer that the problem might be the coil packs, but can't convince them to try swapping them out (no codes).
I also saw the recall about coil packs and am wondering if that might finally fix my car. I wasn't clear from the letter, though: are they replacing the coil packs on ALL affected cars, or only those that are triggering check engine lights (my car never triggers a CEL).
N'Syncro
33
02-16-2020 03:12 PM
firemandan
09-15-2015 08:02 AM
PoisonBeef
09-04-2015 05:29 AM
