Windshield Washer Fluid?
Windshield washer fluid won't spray on windshield.
I filled up the reservoir, took allot, but it was not low enough to trigger the fill light.
Now all I hear is the pump running and no spray out of either nozzle or the rear hatch nozzle.
Disconnected at the front nozzle and no change.
Ideas?
Ideas?
Ideas?
Ideas?
Ideas?
Ideas?
Ideas?
Ideas?
I had the same problem.
I cleaned out my jets and all is now working.
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc abstand-kap einzug-standard"><TBODY><TR><TD class=titel-kap>Removing and installing washer jet</TD></TR></TBODY></TABLE></TD><TD class=spalte-pfeil></TD><TD class=spalte-marg></TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Removing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Carefully pry cap apart slightly -arrows- and lift off.</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
A92-0143.png?t=1360090532
<TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Carefully pull washer jet -2- off connection pipe -arrow-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Installing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>Installation is carried out in the reverse order; note the following:</TD></TR></TBODY></TABLE><TABLE class="cc abstand-standard einzug-standard "><TBODY><TR><TD class=einzug-liste>l </TD><TD>Insert washer jet with spray opening pointing into recess on wiper arm -1-.</TD></TR></TBODY></TABLE>
A92-10128.png?t=1360090565
<TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Cleaning washer jet:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove washer jet.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Rinse washer jet with clear water in opposite direction of spray.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Always blow through washer jet in opposite direction of spray when removing remaining particles of dirt by applying compressed air.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>If spray pattern still does not match specifications, renew the washer jet.</TD></TR></TBODY></TABLE>
Thanks for the posts.
No water, only -40 rated washer fluid used.
No plugged jets, took off a hose at windshield and no washer fluid would come out.
Pump will run, wipers are on, but no washer fluid. If pump is running should there be some pressure to spray the washer fluid?
Would I hear the pump motor running if it is not turning the actual pump impeller?
Are there any relays, where are they located?
Thanks.
Thanks.
Thanks.
Thanks.
Check out the pump
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc abstand-kap einzug-standard"><TBODY><TR><TD class=titel-kap>Removing and installing windscreen and rear window washer pump -V59-</TD></TR></TBODY></TABLE><TABLE class="cc abstand-standard einzug-standard"><TBODY><TR><TD class=wz-liste-kopf>Special tools and workshop equipment required</TD></TR></TBODY></TABLE><TABLE class="cc abstand-standard einzug-standard "><TBODY><TR><TD class=einzug-liste>t </TD><TD>Drip tray</TD></TR></TBODY></TABLE></TD><TD class=spalte-pfeil> </TD><TD class=spalte-marg> </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Removing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Switch off ignition and take out ignition key.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove front wheel (left-side).</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove front wheel housing liner (left-side)</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Unplug electrical connector -3-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Place drip tray under washer fluid reservoir.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Release retaining clips -1- in direction of -arrows- and disconnect washer fluid hoses -2- and -5- from washer pump.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Lift windscreen and rear window washer pump -V59--item 4- out of washer fluid reservoir.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Installing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>Installation is carried out in the reverse order; note the following:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Check sealing grommet for damage.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Install front wheel housing liner (left-side)</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
![Name: AVANTREARWASHERPUMP.png
Size: 38.8 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/87840d1501791994-windshield-washer-fluid-avantrearwasherpump.png)
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc abstand-kap einzug-standard"><TBODY><TR><TD class=titel-kap>Removing and installing washer pump -V5-</TD></TR></TBODY></TABLE><TABLE class="cc abstand-standard einzug-standard"><TBODY><TR><TD class=wz-liste-kopf>Special tools and workshop equipment required</TD></TR></TBODY></TABLE><TABLE class="cc abstand-standard einzug-standard "><TBODY><TR><TD class=einzug-liste>t </TD><TD>Drip tray</TD></TR></TBODY></TABLE></TD><TD class=spalte-pfeil> </TD><TD class=spalte-marg> </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD class=spalte-text><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Removing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Switch off ignition and take out ignition key.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove front wheel (left-side).</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Remove front wheel housing liner (left-side)</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Unplug electrical connector -4-.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Place drip tray under washer fluid reservoir.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Release retaining clip -2- in direction of -arrow- and disconnect washer fluid hose -1- from washer pump for windscreen washer system.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Lift washer pump -V5--item 3- out of washer fluid reservoir.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard absatz-hervor"><TBODY><TR><TD>Installing</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD>Installation is carried out in the reverse order; note the following:</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Check sealing grommet for damage.</TD></TR></TBODY></TABLE><TABLE class="cc einzug-standard abstand-standard "><TBODY><TR><TD class=einzug-liste>– </TD><TD>Install front wheel housing liner (left-side)</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
![Name: FRONTWASHERPUMP.png
Size: 20.3 KB](https://www.audiworld.com/forums/attachments/a6-s6-c6-platform-discussion-58/87841d1501791994-windshield-washer-fluid-frontwasherpump.png)
