Worn front motor mount?
I was looking around underneath my car last night (2005 A6 3.2 Quattro) and noticed this worn rubber mount. Looks like a very worn motor mount? I looked around and didn't see a procedure for changing this. Looks pretty straighforward. Almost looks possible to put a jack under the motor to keep it in place and then remove the 4 bolts holding the mount and replace witha new one. This is at the front of the engine and the mount is bolted to the lower front crossmember.
Is this a pretty common wear item?
I checked all the suspension bits and the entire driveline and this is the only thing I saw that looked worn.
The mount in the picture is the front torque mount, not the side mounts that are mentioned in the previous post.
Not sure where you see the wear on that torque mount, it looks normal. Unless you drive your car in a very abusive manner, that one should not go bad.
Hibiscus Red S4
9
01-18-2008 12:26 PM
AudiSport4000
02-25-2004 05:06 PM
