Xenon problem A6 C6
Hello
Since few days now I have strange problem with headlights in my A6 LeMans 09 plates.
Here are short videos of my problem
If you could guys have a look at this, maybe someone had similar problem as mine before ?
everything else is working fine, led, levelling, etc.
only problem is that headlights switch off itself every 2 minutes, sometimes both of them at same time and sometimes left and right independently.
Its happening on auto and manual, so I assume its not cause by light/rain sensors .
Any advice what could it be or what to check first will be welcome.
Thank You
Thank You
As for wiring harness, connection and relays I will check them at weekend.
Any clues where I can find some diagrams or pictures where relays are ?
Thank You
today I had another fault , this time with engine
Address 01: Engine Labels: NONE
Control Module Part Number: 03L 906 019 AH HW: 03L 906 022 FG
Component and/or Version: R4 2,0L EDC H03 5573
Software Coding: 0105002C02072120
Work Shop Code: WSC 02325 785 00200
ASAM Dataset: EV_ECM20TDI03L906019AH A01003 (AU56)
VCID: 71EDD1F71139
1 Fault Found:
5253 - Exhaust Pressure Sensor 1 (G450): Signal too High
P0473 00 [168] - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 11
Mileage: 87459 km
Date: 2013.07.18
Time: 08:10:44
Readiness: 1 1 0 0 0
maaliish
10
06-10-2007 04:37 PM
AudiBill
11-21-2005 12:19 PM
