A7 retrofit Remove Active Lane assist
Hi
i wanna remove the Active Lane assist from my car
is something that is useless in my country (road with lane mark)
and want get ride of this warning on the cluster
attach my scan
Monday,23,December,2019,17:55:58:59248
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
Workshop Code: 785 02391 000200
VIN: WAUSGAFC1CN001559 License Plate:
Mileage: 204218km-126895mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUSGAFC1CN001559 Mileage: 204218km-126895miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Not registered 0011
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSI H05 0005
Revision: --H05---
Coding: 1A2A0034056600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 002006
ROD: EV_ECM30TFS0214G0907551A_002.rod
VCID: 275D24D85E0A647EEB-8072
1 Fault Found:
6632 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [165] - -
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 56 °C
Intake air temperature: 51 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.085 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 56.25 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 E HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
Shop #: WSC 09396 002 1048576
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 306FCF846BC423C63A-8064
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Revision: -------- Serial number: --------------
Coding: 44A70F0222E5F0404B00
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 0D8A2000000000000000
VCID: 79F932A0F03E228ECD-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000088093004
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0055
Serial number: 18011100040004
Coding: 6603207A1C
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiComfoUDS 002027
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 285F27E453146B06E2-807C
1 Fault Found:
0315 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
Voltage terminal 30: 12.38 V
Outside air temperature: 33.0 °C
Engine speed: 0 /min
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000770027
Coding: 0D072091073E9FE081000884A0003820CF9CD308A209012580 0308453B00
VCID: 2C57DBF44FEC472606-8078
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110112 H32 0051
Serial number: 110121052817
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11247400
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 01 02 2011 00000212
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R09RZ06
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 1002277450
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001101035295
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001101035625
Subsystem 8 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA102032000000162393
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: F3080D85000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001012221167
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001012221196
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 A HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0470
Revision: 00000006
VCID: 2B55D8E84AE2401E0F-807E
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55931034302214
Coding: 202104
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 3979F2A0B8BEE28E8D-806C
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 67DD64D89E8AA47E2B-8032
4 Faults Found:
146688 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Control Module temperature: 47 °C
Voltage terminal 15: 12.308 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
102912 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80011HCC
Coding: 303145313131303030324A55304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3365C0889AD218DE47-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y160001GTA10V
Crash sensor for side airbag: driver side:
Serial number: 3575HRB404T0C15IGH9I
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB4059085G2CORG
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405B0974OKGKJ
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405J0974ONH9L
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405P09GGS4PAD
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405T09GGS7GAC
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KAR000C5
Coding: 0000F4
VCID: 377DF49886AAF4FE7B-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 11 10 2010 11054340
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:41
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 981 M HW: 4G8 920 981 M
Component: TBenUsaAccNv H34 0309
Revision: 18100069 Serial number: 658240111593006
Coding: 0BC601060B03D705020100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 3D71E6B0AC96DEAEA1-8068
1 Fault Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000085057
Coding: 00C1033000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650443561
1 Fault Found:
0023 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Voltage terminal 30: 12.1 V
Voltage terminal 15: 12.1 V
Control Module temperature: 50 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0055
Serial number: 21011100040067
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002010
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 2F6DCCF876FA3C3E23-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00001002253939
Coding: C0581B008F002001000001010101102030303232203232
VCID: 387FF7A48BB4FB8672-806C
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200AFWE0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51D6F07CF64E2E11-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000007
VCID: 2F6DCCF8BEFA3C3E23-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F29.01.1100H010003CD20336ÿ
Subsystem 4 - Serial number: D20336ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F57225E00628002000003
Shop #: WSC 02312 785 00200
VCID: 3F8D9CB8AE9ACCBEB3-806A
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0015031620
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BC58C65C811D64C-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0142702364
Coding: 0126023A20FAF48580B00A8002010000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000021072
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1115763+
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000151265
Coding: 010000
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA100924000000185003
2 Faults Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:41
00218 - Humidity Sensor (G355)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:45
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 465 HW: 4G0 035 465
Component: BO G3 C7 H07 0120
Revision: 05S00000 Serial number: 0011198
VCID: 62CB75CC7DA8C156FC-8036
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 02311100001270
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F57225E00628002000002
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000034385
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A5BDDEC4D185916F4-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0012
Serial number: 110128-0004-014
Coding: 1223A6601002A400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57DBF447EC472606-8078
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 A HW: 4G0 035 082
Component: Radio U SIRIU H51 0068
Revision: AB001007 Serial number: 156AK0B7500431
Coding: 020007010000000001
VCID: 1E33013C0950A5B698-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 HW: 4G0 035 746
Component: H-BNT-NA H48 0294
Revision: -------- Serial number: 031AJ0B7501671
Coding: 090200040303E5FE45168F2E000000031000010000000000
VCID: 64C773D467BCCF660E-8030
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDA1300B4VJ
Subsystem 3 - Part No SW: 4G1 919 612 L HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KAR0002O
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F17224000628002000002
VCID: 428B954CDD68A156DC-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J11F079
Coding: 1020013
VCID: 25412ED0EC06766ED9-8070
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 E HW: 4G8 959 107 A
Component: HDSG-Modul H12 0036
Revision: 12012001 Serial number: 009100204
Coding: 0A3205C100
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 377DF4988EAAF4FE7B-8062
1 Fault Found:
0068 - Warning Buzzer for Rear Lid
B11DF 13 [137] - Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
12.25 V
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0210
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 HW: 4G8 919 604
Component: HeadUpDisplay 023 0042
Revision: 00000000 Serial number: 00000000000000
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7_VW51.rod
VCID: 70EF0F84AB4463C67A-8024
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40023004
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 3169CA8060CE2ACE35-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001102700333
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 7P6 907 217
Component: DPC-SG H27 0038
Revision: -------- Serial number: 262130025421000
Coding: 71160000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 264329DC59007D76D0-8072
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
VCID: 65C16ED06486B66E19-8030
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Control Module temperature: 46 °C
Voltage terminal 15: 12.335 V
Velocity_vehicle_reference: -0.00 m/s
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040182401117
Coding: 03C098080111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 25412ED02406766ED9-8070
2 Faults Found:
0030 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Voltage terminal 15: 12.2 V
Control Module temperature: 47.0 °C
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:51
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FED0CF8B67A7C3E63-803A
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:47)--------------------------
attach my scan
www.Ross-Tech.com
Revision: --H05---
1 Fault Found:
P1647 00 [165] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Revision: --H08---
Coding: 000002
Revision: 00002001
Coding: 6603207A1C
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
Coding: 0045F7
Coding: 02562B
Coding: 853000
Coding: 020300
Revision: 00000006
Coding: 202104
Coding: 3601010201
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Coding: 0000F4
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:41
ROD: EV_RBD4K.rod
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
Coding: 00C1033000
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 00
Coding: 0000007
Coding: 001F00
Coding: 010000
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Time Indication: 0
Date: 2019.12.23
Time: 16:43:45
Coding: 1020013
Coding: 0A3205C100
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:41
12.25 V
Coding: DA0000
Coding: 1411
Coding: 71160000
Coding: 3601010201
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
ROD: EV_BC7.rod
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 204218 km
Date: 2019.12.23
Time: 16:43:51
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
kingcezar1992
A6 (C7 Platform) Discussion
13
03-05-2020 08:44 AM
Colin Penman
11-09-2017 02:17 AM
