Eibach Pro Kit Springs On Non Sport Struts/Shocks?
Hi all,
So I just ordered a set of Eibach Pro Kit springs for my NON-Sport suspension A7, running 19" wheels.
I'm starting to get a bit concerned that the non-sport struts/shocks may not be able to handle the Eibach's and I'll prematurely blow out the non-sport OEM struts/shocks. Can anyone comment on this? Has anyone here done Eibach's or H&R's on OEM non-sport struts/shocks?
Assuming this is a bad idea, what would the recommend be for a full package? I know H&R does coilovers but I wanted to go with Eibach for the slightly better ride quality over the H&R's. Didn't really want to spend the bread on a full upgrade either, just tring to mitigate a bit of body roll.
I was considering the Stasis suspension upgrade and not once did the Stasis rep or the Audi service manager ever mention that the stock OEM struts/shocks would be in danger of premature failure, both of which knew I was looking to upgrade the springs on a non sport suspension.
I feel like I'm getting conflicting info, can someone help shed some light? I'm supposed to have the Eibach's installed this Wednesday.
Thanks.
Thanks.
Hi all,
Thanks.
Thanks.
I hace the same sep but with 20s, non sport shocks, I really don't think ou will have any problem, I don't feel anything wrong with my car besides better handling and the comfort is still there (even with the 20s) relax you will like them without spending on a full setup. You will love them.
Thanks again!
Your struts are relatively new so you shouldn't have a problem.
The only danger of using older OEM struts with lowering springs is if the stem was damaged or had corrosion, it might damage the top seal. If the change was being made on a older car, it would be advisable to change the struts because of the seal scenario and because the struts are worn and it's a ideal time to change them.
I don't want to stiffen the ride with either coilovers or sport struts/shocks so this seemed my best alternative to mitigating the A7's pronounced bodyroll in stock setup.
I believe you're running H&R's correct? If so, are you running thoe on the stock or sport suspension and for how long now.
Thenks for the input Tenspeed.
Lowering and sport springs are going to firm up the ride. Shocks and struts are designed to help keep your tires on the road. They control the action of the spring.
I believe you're running H&R's correct? If so, are you running the on the stock or sport suspension and for how long now.
I assumed I would need an alignment after. How did you know you needed one, pulling...excessive wear?
i see you have a Diavel, great bike! I have an MV Agusta Brutale 910S, love the Italian bikes!!
Thanks again for all your input.
I love my bike, I wish I could use it more often, I used to go to work in it, now only once a week if I can.
