harsh suspension
I just traded in my 2001 A6 4.2 for a 2012 A7 prestige, non-sports package.
I am totally shocked by how harsh this car has turned out to be, I wish I had discovered this prior to purchase. Does anyone know if anything can be done to improve the suppleness of the suspension? Every little roughness in the road in all but the very smoothest brand new pavement, is felt in my teeth. Its a disgrace to call this a luxury sedan, but maybe there is something I can do? I would even consider aftermarket shocks at this point as I love the car otherwise. Any suggestions?
19-, or even 18-inch wheels will allow you to run tires with more sidewall height. Ride quality would improve at the expense of cornering ability.
Also be sure to check your tire pressures. If you go by the door label, it's for max load conditions. Go by the manual which is usually a lot less. Reducing the pressure can make a huge difference in ride.
Im sure you have probably already done this, but have you set the vehicle to comfort mode? It comes in dynamic as standard, and once you move it to comfort mode, it becomes less harsh and performance becomes less aggressive as well obviously.
if the OP is In North America, there is no adjustable suspension in the C7 A6 or A7.
I have 20" wheels, non-sport. I've never felt the ride to be harsh. Actually, a couple days ago I had Eibach springs installed to tighten it up a little and to enhance the look of the car. Oh my god, I can't tell you how much better it rides. It's a bit firmer, not harsh at all. The handling is amazing. It seems faster too, as it moves forward quicker off the line. It stops better and of course, cornering is more precise and stable. And it's even more gorgeous now with the slightly lowered stance.
TIA
I didn't measure the drop but I'd approximate that there was a 1" reduction in the back and about 1.5", 1.7" in the front. I think it's where I want it, and even if it settles a little it'll still be good. I think Eibach states 0.8"-1.2" in back, and 1.5"+ front. I made the purchase mostly for aesthetics but I realized that there is much more to appreciate in its superior handling now.
My avatar is a pic after installation. Today is car wash day so I'll take a few more pics and post tonight.
[QUOTE=vuvision;24351276]What's the drop on the Eibach springs? Can you post some pics?
TIA[/QUOTE
here are some pics...
https://www.audiworld.com/forums/sho....php?t=2834297
TIA[/QUOTE
