LED Headlight High Beam flicker
#11
Wow this car just keeps getting better and better. I assume then that it works with Pandora and various other services as well. You don't have to go and check on my account. I'll do that when I get mine is 6-8 weeks.
#12
Yes, you can definitely use your iphone4 as a bluetooth music device. Meaning, whatever is being played on the phone will be played from the car.
#16
Guys with LED headlights, if you lead you high beams for 15 Second or less do the lights flicker, does our dash board light up light a christmas tree, saying that the dynamic range control is defective, adaptive lighting control is defective, and low and high beams bulbs for left and right side are out.
Also, any one notice, if you turn off the AC the ventilation seats just push warm air up your back. Is that Normal?
I in fact just did some testing and turned on the ventilation on the seat without the AC on. After it's turned on I could feel the air on the back. Then I turned on the AC and wow, the air from the seat became COLD! So the conclusion is that the ventilation on the seats are indeed linked to the AC of the car....
#18
So is bluetooth audio streaming officially supported on the A7 or is an A2DP adapter required? I've seen some say yes it is and I've seen some say no it isn't.
#19
Steelcitymafia
14
08-21-2014 08:45 PM
pushkin
05-19-2011 04:24 PM
lazybeans
05-02-2007 03:25 PM
EuropaVin
07-04-2004 07:21 PM
