Mixing Brake Pads
Mixing Brake Pads
So, I just had my A7 in for the routine 35k service and dealer said the rears are about to hit the wear sensor, however the fronts probably have another 20k miles on them. I'd like to go with Akebono Ceramics next, but there's no point in replacing the fronts if they have that much left.
Obviously, they are recommending replacing the rotors with the pad change so I'm somewhat unsure of what to do. If people have successfully just changed the pads and not rotors at this mileage, I would just turn the rotors and replace all 4 pads at an Indy shop with the Akebono.
If the rotors really do need to be replaced, depending on the wear, would there be any issue leaving the factory pads on front and replacing the rears with new rotors and the Akebono Ceramics?
Sounds like you use the ACC.
Thanks tenspeed. Assuming a reputable Indy shop would be able to measure and advise how much is left.
For the ACC, yes I do use it a bit on longer road trips, and I've read that it utilizes the rears when braking.
vpr1980
11
03-24-2005 09:53 AM
