Outta gas..
Did the stupid thing of having the car die on me as I was approaching the gas station to fill up.
Now i feel like it's not as spritely and my MPG's appear lower on my morning commute. I'm 99.9% certain it's just in my head, and due to morning temps having just dropped to freezing, and possibly even that gas may have been switched to a winter blend.
Curious to hear others' perspectives..are these cars that sensitive to hitting the bottom of the fuel tank or is this likely just my imagination/due to unrelated factors? I always use Shell 93.
You can also do a quik scan with VCDS and see if you set any faults from mis-fires, etc...
Almost all fuel at the gas station contains a blend of ethanol. In the olden days we used to put a bottle of HEAT in the gas tank every fill up in the winter. HEAT is ethanol. Ethanol absorbs water(not a scientific description but I'm not a chemist). In other words any small amount water that might be in modern fuel is absorbed and burned. So no water floating on top of the fuel like we had in days gone by. You should be fine.
bostonS6
New England Discussion
26
05-13-2008 06:03 PM
blk18tq
03-12-2003 04:39 AM
EighTT
08-13-2002 08:14 AM
