When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
What was the fix for this? I am currently getting the same error, plus the turn signals no longer work. Dealership is having a hard time tracking it down.
Thanks
Thanks
I'm having the same problem, did anybody get anywhere with this???
Also have problems with fm reception, the receiver for which is also on the boot and also had the rear brake light replaced due to a fault just before the warranty ran out in late November. Don't suppose you've had either of these problems!
Never got it fixed it was tied to fault in the roof module, it was overheating.
I have the same issue , my cars battery keeps draining , after jumping it gives rear spoiler fault and the won't go down , at the same time gives airbag sign on.
any solutions?
I got the battery changed too through the dealer ship yesterday.
and later this evening the car wouldn't start again , jumped the car and again spoiler and airbag sign.
I have this to on cold startup. The only thing I can think is it happened the first time right after I had something in my trunk hit the inside of the tailgate. It was either a SCUBA tank, propane tank or nuclear bomb. No really something heavy I forgot was in there. I might pull the plastic cover off and look at the wiring at the motor to see if there is something obvious.
Hi, did you solved this problem. I have probably same issue as You "A7 Rear Spoiler Malfunction Fault 03132", I tried to change the same modul as on this video
