Recent MMI and Steering updates
#11
Hi, I received a call from the dealer stating there is a power steering update and a Door seals recall, my car has been tuned and I do not want to take the car to the dealer unnecesarily, do you happen to know what was the power steering update and if you feel any difference at all? thanks
#12
I have had the power steering update on mine. I didn't know about the MMI update until after I picked up my car.
The steering feels more weighted an more direct to me. But then again I was driving a front drive A6 as a loaner and its steering was pretty lite. I'm not sure if it seems heavier because I'm drive been driving a front drive A6 for a few days.
#13
#14
I do not feel my steering wandering and the OP posted "The TSB for this update only states that it address a premature error condition" so I guess I will be avoiding the dealer this time, unless there is a fellow memeber who happens to be a SA and can tell me exactly what to do.
#15
Drove home with various Drive Select settings - nothing's changed; Bose still sounded the same - pretty good to my ears!
#16
He also made me sign a waiver just in case I had chipped my ECU (of which I have not). According to him, this update might also flash the ECU. Less than an hour later, its done, I checked all my Vagcom mods - they're all still there - Yipee!
What I can tell you is that power steering and engine (or main) ECUs are two different things, reflashing the power steering has nothing to do with the other one (that is why you still have your mods), and ALSO when I DID chipped my car I DID lost the VAG com mods (Not all of them by the way, for example Video in Motion was still there) all the lightning mods were gone.
And you didnt feel anything different with the car, I think I will just pass in the steering update, I do not want to risk of them finding out about the tune (by hooking the main computer and run the background diagnostics) for an upgrade that doesnt do much for the car, if something happens that merits going to the dealer I will get my car back to stock (completely stock not just the stock mode of the tune, they saved the image of my car prior of the tune) and then I will get all the updates due.
#17
I just read in a forum from Spain what exactly the fix 48k4 does
"La campaña hace referencia a la dirección asistida: se habían presentado casos en los que, al poner el vehículo en marcha, se encendía el testigo de la unidad que controla la dirección en el cuadro de mandos. Funcionalmente no daba ningún problema. La campaña se basa en una actualización del software de la unidad que corrige ese problema."
translating is "the campaign is in reference to the power steering, there have been cases when at starting the car, there was a warning light of the unit that controls the power steering, functionally there was no problem, the campaign is based in a software update that controls the ECU that fixes this problem"
So more in my favor, I have not seen any problem nor warning light, so no upgrade for me.
Anybody heard about the door seals???
#18
BasicSlvr -
Can you do me a favor and take a photo of your Nav Screen with the updated value and either post here on the forum or send to me via e-mail (deanrose@gmail.com)? I had my 2012 A7 Prestige (Bose) at Audi Dallas today for which the shop foreman indicated that the version I'm on is the latest. I pressed the issue with the service advisor, showed them a copy of your forum post with the exact version and when they looked it up the version they found is the same version that I'm on when I took delivery back in April 2011.
So I would love to have an actual snapshot of your MMI screen to take in a show them.
Thanks for any assistance that you can provide would be appreciated. Thanks
Dean
Here's what mine looks like currently:
![](http://www.deanrose.com/images/AudiMMI.PNG)
Dean
The mmi update is : HN+_US_AU_P0487. The current Nav version is: 8R0060884AD NAR 5.5.5. I'm not sure what the current steering update version is. Your dealer will have the details as I believe the updates are Audi required.
After a few days with the update, I can definately state that the Bose sound is improved. Better imaging, better defined bass and mids.
#19
BasicSlvr -
Dean
Dean
