Second tire sidewall bubble in 1 month - Will Audi exchange all 4 tires?
#11
I was just pointing out that the door sticker is for max loads and the manual provides info for normal loads. If one is using the max load pressure with a normal load, it's essentially like over inflating. Under inflation would be true if under a full load, one doesn't adjust pressure up per the max load recommendation. Also, over inflating has some additional risks associated with a smaller footprint patch on the road, particularly in slippery conditions.
Finally, there's ride comfort vs. handling considerations. I usually go a couple of lbs. higher under normal load than the manual indicates. I find it's a good compromise between the two for my taste.
In any case, I hope you have better luck with the new tires. I have a set of Bridgestone RE970AS Ultra-high Perfomance all seasons and love 'em.
#12
Well, I think what this is referring to is the tread area becomes unyeilding with over pressure and not giving for road debris. OK I understand that. However, for me, the sidewalls were being "bitten" by the rim when hitting a pothole, and lower pressure would make it hit harder. I am a mountain biker and they call this "snake bites" as even if the tire is OK, on tubed tires the rim could cut little slits on either side when coming down on a sharp rock. This bicycle example is sort of what was happening to the Conti's. I am hoping for better results with the Bridgestones, we also got 970 Pole Position tires and just mounted them today. Seem good so far.
Cheers,
Cheers,
#13
Goodyear LS sidewall bubbles 2013 A6
I've had sidewall bubbles in 2 tires after presumed minor impacts of 19" rims. Never happened to me before in 50+ yrs driving. has this happened to others? Will Audi or Goodyear offer compensation?
my dealer says no.
my dealer says no.
Stimps
09-14-2015 07:19 AM
SilverRings
Wheels & Tires Discussion
08-31-2015 05:42 AM
