Side Assist System Fault
I was driving on the highway today and suddenly I got a beep and the message "Side Assist System Fault" showed up. The red light in the door pillar that shows that the Side Assist function is turned on has gone out. I pressed the button to turn it back on, the light came back and the Side Assist has been functioning for the rest of the trip.
I originally turned Side Assist on when I got the car 3 months ago and it has been on and working fine until today.
Has anyone else experienced this?
This is the info I got from the dealer:
"The side assist functions may be impaired and or create a fault on highways that have metal on their medians and on roadways made of concrete. This is normal and you can turn it back on and it will function again. The reason that it tells you there is a fault is to warn the driver that the system is not functioning."
I had the exact same thing happen to me. I was in a tight tunnel, with a metal median, slowing in one lane with cars flying past closely in the other. I figured the radar didn't get a sensible return, and shut itself off. The system has worked flawless after I turned it on right away again, and since then for the past 4 weeks to date.
Scott Chapman
01-10-2018 01:34 PM
ckeck
09-05-2008 08:20 PM
