Simm and USB ?
Hi folks
What is the largest capacity sim cards for the A7? I have both slots, and want to get two cards for it.
Also, how do I connect USB, as I read about this all of the time. Please advise.
Thanks
Thanks
When you pop open the little cover under the DVD slot, there are two sockets, one on either end of the slot. These are SD card sckets, which are memory cards you can plug in with files on them (i.e. music). I don't know what the maximum size is, I had a 32GB card in mine and it worked. I am confident a 64GB would also.
In the center of the slot you may or may not have a SIMM socket, which is there to make a connection to the cellular mobile telephone network (data connection). There is no size associated wth a SIM card.
To use a USB device you need to buy a USB cable, part number 4F0 051 510 G which plugsinto the AMI connector in the center console.
You may be getting things mixed up.
Have a great weekend.
90/90Qs
02-11-2006 01:50 PM
