Vossen
#12
Banned
Banned
Which one is the dual concave? And even each distributor sets their own price, what would be the difference in price (in percentage) vs the old line?
#14
Hmm. The Vossen Precision Series (VPS) are forged vs their "old" lines which are cast wheels.
Forged wheels are stronger and lighter than cast wheels so they call for a higher price point...unless you have Advan (Yokohama) which are cast wheels but extremely light at ~18lbs each. For comparison HRE monoblocks (forged) are ~24lbs each, Volk Racing (forged) ~20lbs each, Vossen Concave Series (cast) ~28lbs each.
It did cross my mind what they will price these at; however, it seems like Vossen may have shot themselves in the foot on MSRP for their new VPS line of wheels due to these factors:
1) Branding: They can't charge HRE prices, since HRE price premium is justified by their branding (brand name). For example, if you wanted Vossen brand wheels you can just pick up their "cheap" cast wheels.
2) Looks: If you want Vossen looks you can again go with their "cheap" cast wheels since they are modeling the VPS line with the same style as their other lines.
Typically wheel companies either do cast wheels or forged wheels. I believe Vossen tried to roll out the Vossen Forged (VF) line about 5 years ago...it didn't sell to well so I believe they stopped production. I wish them luck to succeed this time around!
#15
Banned
#16
#17
Banned
so the Vossen concave wheels(CV5) will be around 3 lbs heavier than my OEM A7? (I am just quoting your posts) do you think these +12 lbs of unsprung weight will affect the performance? I have read unsprung weight affects a lot.
#18
http://www.m3post.com/forums/showthread.php?t=265756
Lots of things make a difference in wheel weights:
1) Size of wheel (18" vs 19" vs 20" etc.)
2) Width of wheel (8.5" vs 10" etc.)
3) Brand and type of tire (Michellin vs Continental, etc.)
Since so many things affect wheel weight you won't notice a difference up to around 6lbs per corner (24lbs all around). However, you will definitely notice a difference when you run 28lb BBS wheels and then swtich to 20lb Volks. Btw you'll probably get 0.6mi/gallon better gas mileage with the Volk vs BBS...its pretty insignificant.
For everyday driving, wheel weights don't matter. If you are tracking a ton, you want the lightest unsprung weight/rotational mass.
#19
I beg to differ. Unsprung weight significantly affects ride quality, which is something you'll appreciate every day you drive your car on normal streets. Conversely, for track use you want the largest, widest wheel/tire combination that will fit. What you lose in acceleration and braking will be more than gained back in increased cornering grip and sharper responses. Of course, a bigger, wider and lighter wheel would be better still, but that combination is harder to achieve at a price mere mortals can afford.
#20
LONESTARS5
12-30-2007 05:42 PM
JoeO
12
09-19-2007 07:54 PM
Phil type 951
04-08-2003 12:42 PM
