'01 S8: Tech details on how to replace the chrome faceplate of the auto lever? Also..
..does anyone have the part # and where to purchase from (other than via dealer)?
Thanks.
Thanks.
<center><img src="http://pictureposter.audiworld.com/13362/tran.jpg"></center><p>
Part # 4D0713111E Buy a used one if you can, a new one is $320 Plus shipping. http://www.impexfap.com/
Selector lever mechanism and controls, disassembling and assembling
Notes:
Lubricate the shift controls at the points specified with G 052 142 A2.
1 - Selector lever handle
Push sleeve - 2 - down, pull button on handle out to stop and pull handle off upward
2 - Sleeve
Check O-ring in sleeve for correct seating or damage
Note:
For all other repair work on the selector lever mechanism, the front center console must be removed.
3 - Cover
With transmission range display and display for shift lock
To remove, unlock holding tabs from bracket
Remove upward, together with insert - 5 - and cable - 4 -
Unclip holder for wiring connector on bracket - 23 - and disconnect connector
4 - Fiber optic cable
With wiring harness and LEDs for basic illumination
5 - Insert
Disconnect from cover - 3 - together with fiber optic cable - 4 -
6 - Bolt
Install together with washer
Qty: 4
7 - Shutter
Unclip wiring holder on bracket - 23 -, disconnect connector
Remove from guide together with individual transmission range display - 8 -
8 - Individual transmission range display
With lamp holder and wiring harness
Unclip from four holding tabs on shutter 7 (slide lamp holder slightly toward center of shutter)
9 - Guide
Notes:
2 - Sleeve
Note:
3 - Cover
5 - Insert
6 - Bolt
Qty: 4
7 - Shutter
9 - Guide
...you need to remove the center console to get to the shifter tabs....at least on the 97-99's you do.....it's a pretty big job!
I'm sure it's a dealer only item.
pw
pw
"Note:
For all other repair work on the selector lever mechanism, the front center console must be removed."
Also:
I'm looking at a wesite right now who sells the part for $320![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Thanks for looking after me though
Also:
DARKiGOD
12-16-2005 08:28 AM
ebb(in memorium)
05-23-2005 03:55 AM
Kinetic0510
04-05-2004 10:20 AM
a4not
05-20-2002 12:23 PM
ACL8
07-27-2001 02:58 PM
