17915 - Idle Control Sys: Lower Regulation Limit Reached
Has anyone ever had this code?
Mine threw this code twice in past few days (had it thrown two years ago too). Now my car is idling very low and actually stalled. Any thoughts?
<center><img src="http://www.tonypai.com/2005_1017Image0001.JPG"></center><p>Do you have Bentley's? They give detailed instructions on troubleshooting and checking the measuring blocks.
P1507
17915
Idle Sys. Learned Value
Lower Limit Attained
2 Dcy
- Check idle air control Page 24-79
Basically, I had a gunked up Idle Air Control and a cracked hose. After I cleaned off the IAC and replaced the hose the problem went away.
The IAC is easy to clean, loosen the three nuts and the IAC comes straight off. Hit it with some brake cleaner and make sure the slide works properly. Clear the codes and see if the problem persists.
P1507
17915
2 Dcy
yes, I do have the bentley and will be going through may car accordingly. I was just interested if anyone else had this happen. Glad to hear you had success with a simple cleaning - hope mine will be that simple too
KEVOZS8
08-25-2012 10:22 AM
a4_1.8t_01
11-07-2008 06:17 PM
