Sponsored by:
Sponsored by:
1998 A8 A/C Low Side Charging Port
Old 08-20-2008, 11:12 AM
New Member
KMcCallum's Avatar
Default 1998 A8 A/C Low Side Charging Port
Anyone know where the A/C charging port is located on my 1998 A8?
Old 08-20-2008, 12:32 PM
Member
jazbo123's Avatar
Default There is none, but some folks remove the pressure switch...
and charge thru that using an adapter. It seems to work for them.
The pressure switch is mounted under the plastic cover near the firewall on US driver (left) side. I also saw a link months ago about adapter sources. Try a search...or maybe Audipages.
Old 08-20-2008, 12:39 PM
Member
DutchDoofus's Avatar
Default Behind the front-fender coming out of the AC radiator ? ...
Pop the hood en look down between the fender and the AC radiator. There should be a filling-thingy sticking out.
On my facelift A8 it's located at the hight of the passenger-side headlight, about 5 inches from the headlight towards the middle of the car. The plug stands proud of a piece of tubing in front of the radiator.
At least, that's how it works on the facelift A8 but also on my trusty 1993 Audi 100 V6.
Old 08-20-2008, 02:03 PM
New Member
SWiseman's Avatar
I believe this is the high side port. be careful here..
Old 08-20-2008, 03:46 PM
A8CT's Avatar
on the facelift cars it's near the master cylinder, under the black cover.
Old 08-20-2008, 04:05 PM
Junior Member
TOMAS7's Avatar
Default Paul's link
<ul><li><a href="https://forums.audiworld.com/a8/msgs/135287.phtml">https://forums.audiworld.com/a8/msgs/135287.phtml</a</li></ul>
Old 08-20-2008, 04:06 PM
Junior Member
TOMAS7's Avatar
Default ^^^adapter link^^^
<ul><li><a href="https://forums.audiworld.com/a8/msgs/135337.phtml">https://forums.audiworld.com/a8/msgs/135337.phtml</a</li></ul>
Old 08-21-2008, 03:47 AM
New Member
KMcCallum's Avatar
Default Re: There is none, but some folks remove the pressure switch...
I believe the correct "low side" port is the one located near the brake master cylinder. Unfortunitally the fitting is not compatible with the "quick disconnect" fittings available with R134 refrigriant. There must be an adapter for this. Anyone know about this?
RangeK1D
9
02-20-2017 11:28 AM
matt a8
06-21-2012 04:26 AM
TabulaRasa
Audi Original "S" Cars
11-09-2008 03:29 PM
AudiChan
10-26-2006 04:06 PM
All-Audi-Home
06-24-2005 07:54 AM
Quick Reply: 1998 A8 A/C Low Side Charging Port
