2000 Audi A8 engine
2000 Audi A8 engine
Both the S8 and A8 are 4.2, the A8 having only 310 HP, and the S8 with an amazing 360 HP...
I found a chip that increases the A8 by 22 HP, but is there a chip that will bring it to S8 levels (50+ HP) or more?
S8 has a higher compression ratio, and ...
since HP peaks at 6200 rpm in the A8 versus 7000 rpm in the S8, I'd be very surprised if they use the same cams. For the same reason, the "short length" of the variable length runners of the intake manifold is probably shorter in the S8.
derfA8L
04-10-2012 02:14 PM
Audis or VWs 4Life
02-02-2012 02:19 PM
audiquatro75
01-11-2004 11:19 PM
