A8 to A8L brake upgrade questions..
Since i am looking for what is needed to get to upgrade.. im hoping its only a caliper carrier to allow for the slightly larger rotors to be added..
here is what i found
A8
Front (312x25)
w/ ATE Calipers
A8L
Front (323x30)
w/ Girling Calipers
??? Unknown
Front-w/Sensors (8 Pad)
w/ Lucas Calipers
321x30 Rotors
S8
Front - w/ Sensor
w/ Brembo Calipers
345x30 mm Rotors
Can anyone tell me what the 8 pad set is for the front with the 321X30?
So far mechanics have told me that it should only be a $100 a set bracket that will allow the A8 to gain the .5 inches in the front and the 1 inch in the rear for the A8L rotors. Same caliper and pads.
A8
Front (312x25)
w/ ATE Calipers
A8L
Front (323x30)
w/ Girling Calipers
??? Unknown
w/ Lucas Calipers
321x30 Rotors
S8
Front - w/ Sensor
w/ Brembo Calipers
345x30 mm Rotors
That might be a real nice upgrade for 97-99 users
However, new calipers at the Audi dealer is probably as expensive as my Porsche 996 calipers.
pw
pw
So keep your exisiting caliper and use the new rotor and carrier?
Wouldn't be bad......but you would still have the single piston caliper.
However, you could find the 4 pad S4 calipers (I believe they are two piston) that come on the 00 and newer cars pretty cheap from somebody who upgraded.
pw
pw
speedymon
06-15-2007 10:33 AM
Boba Fett
12-24-2000 10:29 AM
