A8 with dtc codes
#11
Just to clarify
Are groups 0/3, 4, 5 = 003,004,005 on vagcom in engine module?
For WOT are you in neutral(stationary) or is car being road tested?
Jay<ul><li><a href="http://www.ross-tech.com/vag-com/m_blocks/001-009.html">http://www.ross-tech.com/vag-com/m_blocks/001-009.html</a</li></ul>
#13
I wanted report back concerning this post. The car started to show transmission shifting probs along with misfire,lean & rich trim DTC's. It whould down & upshift on acceleration causing car to lurch. The tranny went into limp mode & showed DTC 17114 incorrect gear ratio. I told my mechanic to chage the MAF. He did said it didn't solve the problem & put the original back in. I took the car to the dealer. They chaged the MAF and the car is cured. They think the MAF my mechanic had was a defective part. I haven't used VAG on a WOT run to see max airflow yet. I'll check that out over the weekend.
Laguna
08-20-2007 06:11 PM
MingsS4
10
04-07-2006 03:02 PM
Ferris TMK
9
05-24-2001 01:18 PM
