A8 tranny again
a8 tranny is acting up again. slow speeds there is a pretty bad shutter. If i put it in manual and run the gears out a little more not as bad. ? torque converter, or should I do the transmission recode. I am not giving up on this car after seeing all the 200k post and mine has 100k. I need to be at carisle with this car on the 17 and 18th of May
Help Auditrippn
Help Auditrippn
Have 90k on my 98 A8. Recoded the tranny. Dealer did the fluid/filter at 48k for me. Anyway, the "shuttering" (almost like violent hunting)ONLY happens in 2nd gear between 1700 & 2100 rpm's if I need to accelerate up an incline OR give it a generous amount of gas on a level surface in 2nd in that rpm range, otherwise she still runs great. For now I try my best to avoid those situations, usually by keeping the rpm's above 2100 until I figure this out. The transmission output flange seal is currently leaking, but I doubt that could be related.
Any thoughts?
Any thoughts?
I ordered a filter and atf last week. Just have to find some lubeguard. As always I appreciate your input. Thanks.
http://www.otsparts.com/products.htm
Tozo
You made no comment about this little device, Might it up line pressure for those who could use a bit faster engagement?
Wouldn't it be nice to "hack the code" of the TCM ;-)
CalG
Tozo
CalG
They are from the late 80's early 90's BMW and Land Rover. Most of them had a governor to shift. Late model Audi/BMW (late 90's to today) run high line pressure already. We all know what could happen if someone increase the pressure even more. But hey if they sell it someone must approved it, right?
<img src="http://pictureposter.audiworld.com/80919/dscn1872.jpg">
low944
05-17-2012 05:42 PM
2A8Lemons
10-31-2007 12:46 PM
paulfern2000
9
08-27-2007 12:30 PM
Adrian410225
10
12-23-2004 08:10 AM
