A8 transmission Interchange
#11
Re: Has anyone replaced a DTE with a DPZ?
I have replaced the Valve Body on my DTE with a unit from a later model. I forget the designation. Absolutely no problems with the electrical, electronics etc.
As mentioned. if the wiring diagrams are the same, all the "likes" should interchange without a worry.
YMMV
Cal
YMMV
Cal
#14
2001 Audi A8L FBF trans
Hello I have a 2001 Audi a 8L and I want to find out I'm if you're below quote that you gave is accurate I for my car as well and all the Fbf transmissions I find are very expensive and I wanted to find out if I could put in as a EDG from 2003
The original 97' that was in the car is on the bench right now, I forgot the code. The 98' in the car works perfect, I haven't even looked at the code. They all interchangeable. I did this numerous times. The post facelift has a shorter final drive ratio, but it is hardly noticeable. You can use any 5HP24A tranny in your car CUE, DPZ, DSL, DSM, DTD, DTE, ELZ, EDG, FBE, FBF, FUM, FUN, GLA except the S8 tranny DYM, ECX, ECY, FBG.
#16
I put later model units in both of my 2001's the ones i put in were code "FUN" i can't rememeber what i pulled out but it was different.
#17
On the subject of replacing transmissions
My 200K 2000 A8 is in need of major engine repair and I would like to put my rebuilt transmission with 50K miles on it in a running A8.
this would be the transmission 3rd car.
If you have an A8 with a bad transmission that is otherwise in really good shape - let me know.
Thanks
Thanks
#18
Hi Gents
I have 1997 A8 D2 with 3.7 FWD (engine AEW. So by catalog my transmission should be CJZ, however, when I bought the car it was something different in it and it had always a problem. However, recently I found out that for FWD must be 5HP19FL. So, I found here a rebuilt tranny gearbox EFR also 5HP19FL. My question is if it could fit and work with my car? I do not have much of a choices in the country where I am now located. That is why my question is kind of weird but important for me to know.
I would appreciate any ideas.
Thanks
Thanks
97RoninA8
54
05-19-2007 04:07 PM
KaMaKaZieP -ALUMIN8-
10-06-2004 08:54 AM
BrooklynA4
11-14-2002 05:50 AM
5hp24, a8, audi, dsm, dte, engines, fbe, interchange, interchangeable, interchanges, models, tranny, transmission, transmissions, zf
