ABS and Auto Trans Fault Code - Help please
I have had 01119 before but never the tranny 17095. I'm thinking the 17095 is likely related to my recent tranny flush/fill. Is the temp sensor external and easily accessed?
Address 03: ABS Brakes
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 02: Auto Trans
Part No: 4D0 927 156 EM
Component: AG5 01L 4.2l5V USA 1011
Coding: 01102
Shop #: WSC 02313
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 35-10 - - - Intermittent
Coding: 08397
Shop #: WSC 02313
1 Fault Found:
Coding: 01102
Shop #: WSC 02313
1 Fault Found:
Might try to stop by this weekend. Also want to see if Vag-Com can turn off washer fluid level warning. It is full but, for some reason, has been giving a warning for more than a month now. No drips or leaks coming from anywhere; 'Tis quite annoying.
No, haven't tried anything with it yet. It's kind of funny, but I'm one of those die-hard Rain-X guys, so I rarely use my wipers, and especially never the windshield washers. I'm pretty sure that I had the same fluid in my A8 for the 4 years I owned it! I definitely only replaced the wiper blades once. Needless to say, it's ironic to me that I've had a warning for a feature I will rarely ever use. Will give a ring.
My2ndS4
08-10-2005 02:44 PM
