ABS light back on
Posted a note a few days back which PaulW kindly responded on. As suggested I cleared the codes and am now just getting the following.
VAG-COM Version: Beta 408.0-UD
Control Module Part Number: 4D0 907 558 J
Component and/or Version: 4.2L V8/5V G 0004
Software Coding: 05753
Work Shop Code: WSC 23133
Additional Info: WAUGU54D91N004580 AUZ7Z0Y1491270
2 Faults Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
Control Module Part Number: 4D0 907 389 E
Component and/or Version: ABS/ESP allrad D46
Software Coding: 08397
Work Shop Code: WSC 02313
1 Fault Found:
18264 - Throttle Potentiometer (G69): Error Message from ECU
P1856 - 35-10 - - - Intermittent
Any suggestion on what the next step should be?
Thanks
Ron
2001 S8
2 Faults Found:
1 Fault Found:
Thanks
Ron
2001 S8
The_Jerbel (Jordan)
07-04-2007 04:03 PM
