ABS Light On, ESP OFF Light is On following a weird unexpected braking while accelerating...
<center><img src="http://www.epicfoto.com/pics/ronin/ronin_back.jpg"></center><p>Yesterday while doing about 80ish, while accelerating I shifted from 5th into 4th but my hand slipped on the tiptronic shifter (I only got the shifter to about halfway) and it felt like the car suddenly braked... (almost like hitting a wall) the ABS light came on and the ESP off light came on... Everything was okay after that but when I turned off the car and turned it back on the Check engine light came on...
Is this the dreaded transmission thump? I drove the car about 15 miles after that and it didn't happen again, the car still shifts very smoothly in all gears and has for the past 6 months since I got the car...
I plan on getting the Ross Tech software asap, but has anyone had any BTDT's before I do?
Anyone know of a good independent shop in the seattle/Renton?
Thanks!
David
2000 Audi A8L 130k Miles
Thanks!
David
<center><img src="http://www.epicfoto.com/pics/ronin/ronin_back.jpg"></center><p>And of course I forgot to get the manual.. ordering that today... but here is what I got
I have a bad feeling this might be expensive:
Engine:
2 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0010 1101
ABS Brakes:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Auto Trans
Part No: 4D0 927 156 CP
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 02314
1 Fault Found:
P1857 - 35-00 - -
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Engine:
2 Faults Found:
P0102 - 35-00 - -
ABS Brakes:
P1857 - 35-00 - -
Auto Trans
Coding: 00002
Shop #: WSC 02314
1 Fault Found:
P1857 - 35-00 - -
camikazi2k
03-05-2006 01:29 PM
Swank4
08-29-2005 02:21 PM
geiswiz
12-08-2001 02:40 PM
