ABS lights on, could someone give me advice (more inside)
I got the car month ago and now it is like x-mas tree.
On may way back from work I got CEL a little bit after that I got the ABS light on. I pulled the codes, I know the CEL is coming from vacuum leak somewhere, already made a post about that and tracing that one, I found one of the vacuum lines really mushy and cut it 1/2 and connected it back to the diapham behind the engine, we will see tomorrow but here are the codes.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4D0 907 560 CG
Component and/or Version: 4.2L V8/5V G 0002
Software Coding: 06753
Work Shop Code: WSC 02314
Additional Info: WAUGU44D12N001040 AUZ7Z0A1853652
2 Faults Found:
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow
P1423 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Control Module Part Number: 4D0 927 156 EH
Component and/or Version: AG5 01L 4.2l5V USA 1010
Software Coding: 01102
1 Fault Found:
17087 - Brake Switch B Circuit Malfunction
P0703 - 35-10 - - - Intermittent
Control Module Part Number: 4D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 08397
Work Shop Code: WSC 02313
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
2 Faults Found:
P1423 - 35-00 - -
1 Fault Found:
1 Fault Found:
P1423
17831
Bank 1, secondary air system
Throughput too small 1)
Check secondary air pump fuse
Check vacuum hoses
Check hoses from pump to secondary air inlet valve
=> 8-cyl. Engine, Mechanical Components; Repair group 26; Secondary air system
1) With this fault the engine control unit only switches on exhaust gas warning lamp (MIL), if fault has been re-detected after two engine re-starts. Significance of MIL warning lamp => 01-6
P0571
16955
Brake light switch -F
Implausible signal
Check brake light switch and brake pedal switch => Page 24-190
17831
Check vacuum hoses
P0571
16955
Implausible signal
