Air pump question--2001 A8L
My mechanic tells me that the VAG codes show an air pump issue on my 2001 A8L. I recall from prior threads that the first area to look at are hoses, but if it turns out a new pump is needed, any idea where to obtain a cheap one?
Thanks in advance
Bill
Thanks in advance
Bill
Most likely the hoses
<ul><li><a href="https://forums.audiworld.com/a8/msgs/19663.phtml">Everything you need to know to check it yourself, just look at the little hose</a></li></ul>
Re: Most likely the hoses
Thank you, Paul.
I do recall this whole write up and intended to print it out and give it to my mechanic, but I have been hearing a noise up front which I fear may have been the pump. Will find out tomorrow. Thanks for the fast response.
Re: Air pump question--2001 A8L
Hoses it was. Thanks for the feedback.
nkrug
09-01-2006 04:11 AM
maaliish
02-21-2006 12:44 PM
DARKiGOD
07-05-2005 05:01 PM
2.7TToronto
06-09-2003 09:18 AM
