answer to a8 fuel pump blues
#12
Be very careful when installing it. They are very tempramental to any type seal leak in the pump reservoir. It is easy to check though. After you have installed the pump; you need to put at least a 1/2 gallon of gas in if the tank is below 1/2 when you remove to fill the pump reservoir. Drive the car around for about 10 to 20 miles. (Carry an extra gallon of gas) If it dies; you either have not put the seals back correctly or one is mislodged. If there is no problem; you have everything back correctly. Please note that this only works if the tank is less than half empty. Otherwise; the gas is flowing over the top of the reservoir. Peter
#18
Hi everyone, just thought this might be helpful for people with similar problem. We sell these pumps on our website, actually we have sold to quite few customers in US. Shipping takes 2-4 business days from UK.
http://www.worldcarparts.co.uk/tabid...5/Default.aspx
Same issue here in UK as well regarding only the whole assembly being available from the main dealer
Zumkopf
08-15-2018 06:02 AM
