antifreeze leak on top of the oil pan
i have a leak its not bad but i looked under the car to see where it is leaking from and there is no sign of leaks on the bottom of the car,the hoses arent leaking, but i see it dripping from the top of the oil pan, it has to be leaking from the middle of the engine some where does anyone know exactly where is the leak, thanks
or if it is the passenger side it could be the oil cooler. You need to try to trace the leak back to the source, since there are so many possible sources, however.
kingofthe4rings
Mid Atlantic Discussion
06-22-2005 04:51 AM
booker
03-03-2002 08:06 PM
