Anybody know the size of the pinch bolt? : - [
Don't know the size unfortunately, but a couple of questions... Did you remove the big collar bolt in the hub first? Secondly, are you <i><b>sure</b></i> you need to be messing with the wheel bearing? The troll is actually right that it needs to be pressed out via a hydraulic press at a shop. I suppose you can just bring the housing in to them. But getting the front housing out is no picnic to be sure. :-(
I still need the correct size of the pinc bolt in order to replace it. I guess I could just go to Lowe's and get a similar 16mm nut with corresponding bolt of the same size.
That happened to me before with the inner ring sticking on the spindle. I had to use a cutting wheel on my Rotozip to cut it off. Painful memories coming back to me...
I soak them in the requisite PB Blaster and then hit them with my impact wrench. That gets them broken loose and spining inside the housing. from there, a small punch and a hammer drives them right out. In rare cases I have to raise and lower the suspension to take the pinch off the pinch bolt.
