Anyone seen this sign "(0)" need new pads! - advice?
Looks like I need new rear pads. I'm going to try to do this myself using audipages instructions. Other than on my 944turboS I've never been able to change brakes(no tools needed, just slide out). I always end up having someone else finish the job. I found pads @ EAS discount on the Web for $31-33 a set. My choices are pagid, ate(teves) or Textar. Anyone have an opinion?
I believe the sensor is just on the front brake pads. I checked both front and rear pads for wear and I have 1/4" or more on both front and rear pads. I will be installing rotors and pads in a short time. You may need rear pads, I have no clue as to which type may be best. But if the sensor is on, then you will need to install front pads also to get the sensor to go off.
I would go with stock pads for sure. If you start mixing and matching compounds on the front and rear, you will most likely get a change in pedal feel and could be applying the wrong pressures front and rear due to different compounds.
You might also get chronic squealing.
If you go with all stock stuff, you will get good brake performance and minimal squeal.
Those pads make so much dust its crazy. I like the Padgid ones for a stock type pad. Basically a good all around pad for everyday use. Decent bite, good quality and low dust. Besides its the rear brakes we are talking here its not like these do all that much anyway. As for Pauls comments about mixing compounds. I have never heard anything about that in the many years I have been on multiple Audi lists. Not to say that he is wrong, but it struck me when I read his post. As for changing the rear pads. I found them harder than the fronts. Make sure you loosen the bleeder nipple when pushing the pistons back into the caliper. They may be required to be screwed back in. A large C clamp helps with that. There is a Leslie or Lisle or something like that manufacture of a tool that is basically a cube with the different piston pattern (key) that you can use to push, turn back in there. I never bought one, I just pulled the whole caliper off, put it on my bench and beat the hell out of it to get it back in there ( what a pain ) I highly reccomend the MOTIVE Pressure bleeder. Makes the job a breeze! Mitty Vac sucks, litteraly and figurativley!
HTH
Dan Hamren
98 A8 96 A6 90 V8
previous 87 5kcsqa x2 89 80q 90 CQ 85 4kq 82 c
HTH
Dan Hamren
98 A8 96 A6 90 V8
Dumb question, but hw many boxes of the Hawk HPS pads do I need to replace all pads, front and back?
Don fvcking Juan
04-25-2007 09:36 PM
veryfastS4
14
09-24-2004 04:32 PM
