Big bang
Big bang
<center><img src="http://pictureposter.audiworld.com/59720/p1060288.jpg%20,http://pictureposter.audiworld.com/59720/p1060279.jpg"></center><p>(4.2 Quattro) When my starter motor engaged there was a big bang which sounded like a backfire. The engine didn't start so I tried again. The starter was sluggish but started the engine followed by noises indicating all was not well in the starter department. The noises disappeared so I drove 10 miles home. I have removed the starter and found that the drive end bearing housing has been broken off (new brittle fracture - see photo and the broken bits have disappeared into the starter ring/torque converter. The broken casting appears to be made of aluminum and does not appear to have done any significant damage to the starter ring and torque converter. I have examined the starter ring teeth and attach a photo of the most damaged/worn (the fresh scratches were made by my screwdriver turning the engine). I am attributing the failure to worn drive pinion teeth trying to jump a tooth. My dilemma is what about the broken bit(s)that disappeared into the starter ring/torque converter area. I don't fancy removing the transmission to remove them, but dare I leave them, bearing in mind they have been in there for 10 miles already? Has anyone else experienced this problem or am I the first again?
Thoughts on your problem
Your pic won't come up for me (heavy firewalls)so I don't know how big the bits are. Usually the whole nose cracks but sort of stays put. You might consult with a couple of starter rebuilders and see if they have an opinion.
It sounds sort of draconian but you could perhaps drill or grind a small inspection and removal hole in the bellhousing. The patch it. If a piece gets jiggled up into the ring gear you may have one from the inside out.
Another possibility would be inject a small quantity of liquid epoxy, in the bottom, tie the bits down. Don't glue the tranny to the block!
Neither of these is the "right" way, needless to say.
akingzkid
14
09-06-2018 03:42 AM
isleblue65
12
02-20-2013 07:14 PM
audithepeanut
10-16-2008 04:39 AM
gateway
09-29-2008 01:33 PM
