Boy o boy, there are days that I hate this car.
#15
Can that area be sealed off?
I was thinking of putting some blocks of closed-cell foam around the HVAC intake to keep leaves and (some) water from getting under there.
Pipe insulation or foam packing materal perhaps.
Thoughts?
-Joel.
Thoughts?
-Joel.
#17
Re: Boy o boy, there are days that I hate this car.
NO PROBLEM, BIT OF HANDY WORK AND TWO HOURS LATER YOUR DONE. MAIN DRAIN PLUGS ARE ACCESSIBLE BELOW BLOWER FAN ASSEMBLY RIGHT NEXT TO YOUR ECU ASSEMBLY. DISMANTEL BOTH INTERNALS (ABS COMPUTER, ENGINE MANAGEMENT C, BLOWERFAN, SMALLER CASING ETC. REMEMBER ALL LAYOUT OF WIRING . YOU'LL NEED TO REMOVE THE WHOLE CASING. WE PUSHED THE RUBBER FEEDERS THROUGH. THERE IS ALSO A BIG RUBBER SEAL THE SIZE OFF YOUR HAND ON THE PASSENGER SIDE LOWER FIRE WALL WHICH NEEDS TO BE IN PLACE CORRECTLY. YOU'LL BE ABLE TO GET TO BOTH AT THE SAME TIME. CHEERS FROM DOWN UNDER.
PS: SORRY ABOUT THE SPELLING, I'M BETTER IN GERMAN.
badinstincts
11-12-2006 09:40 AM
