Brake Pads Worn Indicator and VAG COM
Hello. I have the "Brake Pads Worn" indicator showing up on my center console (the circle with the half-circles on the outside left and right edges of the circle) of my '03 S8. I am pretty sure the pads are OK because they were just replaced about 10k miles ago or so.
Any way I can use my VAG COM to diagnose the individual wheel(s) that is causing the indicator light? Obviously I'd like to narrow down the search from 4 possibilities to one before I get on the ground and get my hands dirty . . .
Thanks.
-Jeff
Thanks.
-Jeff
You can figure out which side it is by wiggling the wires and try and fix it, or you can jump it out all together.<ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/brakesensorshort.html">Here's the procedure and there is a link to the other one</a></li></ul>
RR
03-25-2002 03:37 PM
