Brake updgrade/replacement woes...
So the brakes on my baby are toasted at 120k and its time to replace the whole shabang, pads, disc fulid.
im all set with pads and fluid, i think its aparent that the ds2500's and super blue fluid are the choice to go with but i cant make a decision on discs.
do you guys find it worth the extra cost of drilled/slotted rotors? is the performance gain worth not being able to refinish them? how many miles can get out of a set?
are there upgraded rotors that are not slotted/drilled?
whats the consensus? and where is the best place to buy rotors from..cost/performance trade off i the best factor
as always thanks in advance for you help and guidance.
-Bq
-Bq
With the DS2500 pads, I would try to find a slotted rotor, based on a quality rotor like Brembo. As far as lifetime of the rotor, you should be able to get 40-50 K miles out of a set. They really aren't all that expensive if you shop around.
...rotor options.
In the end, I went with OE non-slotted Brembos with the pads / fluid you note. Awesome performance, and very easy on the wallet. Slotted's started getting pricey. I've yet to be left wanting for more braking performance - uh uh.
Raceshopper.com for the pads, forget source for rotors may have been like VWAudiparts.com or something...
Good luck, HTH.
Good luck, HTH.
...Does anyone know if G2 makes just the clear laquer so I can clean and restore them without painting them?
<center><img src="http://www.stoptech.com/images/head_productinfo.jpg"></center><p><ul><li><a href="http://www.stoptech.com/user/ProductDetailsN.asp?id=2045&skuid=15341&ca tid=5">StopTECH replacement rotors for the 2003 S8 - Drilled OR Slotted - Front and Rear</a></li></ul>
<center><img src="http://www.movit.de/images/titelaston.jpg"></center><p>
... MOV'IT has made Audi brake kits for years. Be prepared to pay a LOT for them tho.
Just another option.
The now defunct BIRA brake kits were close copies of a low end MOV'IT setup.
When I investigated in 2004, I received these pricing quotes for my 1999 A8
Front brakes
322x32 kit with 4 piston calipers cost 2600 EUR net
342x34 kit with 4 piston calipers cost 3000 EUR net
342x34 kit with 6 piston billet calipers cost 4000 EUR net
370x35 kit with 4 piston calipers cost 3875 EUR net
370x35 kit with 6 piston billet calipers cost 5000 EUR net
380x32 kit with 4 piston calipers cost 4000 EUR net
380x32 kit with 6 piston calipers cost 5200 EUR net
The salesman I spoke to implied that these prices are semi-negotiable.
Front brakes
and David Zeckhausen (who incidentally bailed after I started asking questions), I ended up with the StopTech Sport Stops. Centric parts bought Stoptech and as I recall rebranded their "premium" to Stoptech Sport Stops. Cost was $500 for all four corners.
HTH,
Mark
HTH,
Mark
AvantMnkyA4
Brakes Discussion
07-28-2006 10:52 AM
meetTHEtwins
10
04-29-2004 04:23 PM
LCP
01-07-2003 05:00 AM
gecko
03-22-2002 09:50 AM
ND4SPEED
01-30-2002 02:02 AM
