Sponsored by:
Sponsored by:
A/C drain cowl blocked...
Old 07-22-2013, 09:50 AM
  #21
nickam's Avatar
Can someone tell if the procedure will be the same for my Allroad 2004 or it's way different?
Old 07-22-2013, 01:42 PM
  #22
Kneale Brownson's Avatar
Allroad's cowl drain is under the battery tray: http://forums.quattroworld.com/allroad/msgs/4632.phtml
Old 07-31-2013, 12:43 AM
  #23
A 8
A 8's Avatar
Originally Posted by silverd2
As I understand it, the drain hoses are at each end of one common tray under the evaporator. I used this method, which I assume you're trying:
http://www.audipages.com/Tech_Articl...tordrains.html
It worked easily for me.
BUT the Bentley manual, without a detailed explanation, says each hose can be removed by pulling it up out of the central tunnel. The large orange grommet (plugs into side of console) is an integral part of the hose.
If you try this, I'd like to see a report...theoretically the hose simple feeds back into place, then grommet plugs into hole with it's double lip.
WARNING : I've never tried this, but could be an easy fix...taking the hose out to clean it.
Just came across this and am not sure anyone answered this but you can safely take out the whole orange thing, I've done it many times and flushed it with water to get ALL the muck out. Its like stuff grows in them and eventually they don't open.
Just blowing compressed will open them but very likely they will not fully clean. I get a bit of silicone on them as well in an attempt to keep from sticking again.
It's a little tricky getting them properly seated again but with a small screwdriver its relatively easy to pop them into place again.
I am trying a preventive action once a year in setting the blower to full and shutting down all the air outlets, not sure it helps yet but we will see if it holds longer then before.
Old 07-23-2014, 11:38 AM
  #24
YRA928's Avatar
For those without access to compressed air, try using the compressed air cartridge from a bike tire inflation kit. Most bike shops have this and they are not expensive. Used this method on my car and it worked well. The orange A/C drains are flexible enough to fit over the top of the mouth of the cartridge making it leak resistant.
mschjone
Q7 MK 1 Discussion
16
06-30-2022 05:46 AM
reith
06-25-2020 09:58 AM
Exerqtor
04-19-2013 04:10 AM
A8bil
11-09-2008 09:51 AM
yamahapro361
08-09-2003 10:34 PM
Quick Reply: A/C drain cowl blocked...
