A/C recharge valve location
ok, but i see this isn't exactly the right procedure. how do you normally recharge the system? I mean remove the moisture and any other stuff this guy talks about (that can cause long term damage). thx
To do other than adding a little gas you need a gauge set and vacuum pump, the purpose of which is to pump down the system until water literally boils off and is sucked out. Water in the system is bad for several reasons. So is air (it had the water in it0 because it is noncondensible and also contains O2.
The system has a bag-o-dryer granules in it that will capture a limited amount of water. Also, if the system will hold a 29.5" or better vacuum, that is an indication it does not have a big leak. All systems leak a little gas over the years because they have a carbon/ceramic seal on the compressor nose, and various o-rings and rubber hoses. I just added a little R134a to a Volvo 960 and dropped the vent temp to 48 degrees (from 80). Took 20 minutes.
Adding a bit of gas is the first thing to try.
Based on your questions I'd let somone else do it. There are real dangers. Any rad/AC shop can add gas, you don't need the dealer. More gas is not better, past a point.
back2black
06-23-2004 05:13 PM
mrwho13
04-08-2002 12:43 PM
