call me dumb.... but where is the dipstick to check the transmission fluid
i can't seem to find it.. if it's not there how does one check the transmission fluid levels?
Re: call me dumb.... but where is the dipstick to check the transmission fluid
our gbox's are sealed there isnt one..check this<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission.html">audipages</a></li></ul>
If it's a high pitched noise, it's most likely the filter is dirty
It drops too much pressure, and the hydraulic pump cavitates....you need to do a fluid and filter change.
how much damage am i doing in the interm if i continue to drive the car with a clogged filter
i can't get a damm appointment at the dealer until next week..... can most shops do this type of repair??
Squeal Noise? when? cold starts in gear or not in gear?
I once had the noise briefly between 1st and 2nd gear, esp.when cold and at a low rpm gear change. The cause was a low fluid level due to a popular shop not sealing my filter properly which caused a leak when I did the tranny fluid with the T belt.
i called them ... they're booked solid for 3weeks
the guy said it could possibly be the alternator, since the transmission is still shifting rather smoothly.. i'll have to look at the alternator later today.
the only codes i got from the OBD was
P1280-- fuel air metering/manfacutre Contrl
and a DTC PENDING code (whatever that means)
P0321-- Ignition/Dist
Engined Speed Input
CKT Range/Perf
Engined Speed Input
CKT Range/Perf
the squeal/kazoo sound is constant ESPECIALLY with the cold
went to the dealer yesterday for a "look", and he thinks it may be a TENSION belt coming loose because the noise varies with rpms and noticeable with the car in park/neutral... but they could not get me in because "we're booked solid"
could it still be the transmission filter??
