CAN bus vs K bus?
what are the differences between these two? what do they control?
I purchased a Concert II head unit to install in my 99 A8, but the Concert II has a CAN bus and the K bus; whereas the Concert I has only the K line. I can program the Concert II via WAG-COM via the K line (I think that is how it is programmed) so what is the CAN bus used in the Concert II ?
with names like Clock, Data and Enable, whereas the K-wire is just one wire.
I've never heard of the K-wire being used to operate things -- I think it's only for diagnostics. Anyone know otherwise?
I see that the concert II has a different pinout (due mostly to the CAN bus, I think). If I would rewire to match all outputs that are similar, what would I lose going from Concert I to II?
below is the pinout of Concert I (k-bus)
<img src="http://33rpm.com/images/audi/concert1pinout.jpg">
this one below is the pinout of the Concert II (can/k bus)
<img src="http://33rpm.com/images/audi/concertIIpinout.jpg">
I have just recently fitted my Audi A6 1998 model (non can-bus) with the new Concert II radio. However, I have noticed a few faults with the setup, these are:
1. Illumination problems at night with the backlights not switching on with the headlights (since fixed with a tech article).
2. Auto power off failure with the ignition.
3. Auto power off after an hour.
4. Front speakers not operating on occasions.
Does anybody know how to fix the issue of the auto power off after an hour? and also how to fix the problem of the ignition power off. I believe it is probably an easy fix by soldering another wire to the PCB and fixing it to the bus connector that has the S-Cont pin missing to operate this function, but as yet I am unsure which pin inside the H/U to solder this to.
If anyone has experienced these problems, could you email me and let me know how you have found a fix.
Thanks,
Martin
Thanks,
Martin
pat33
10-05-2004 02:20 PM
gateway
02-29-2004 01:35 PM
