Can someone tell me the pin assignments for a pre-facelift S8 instrument cluster please?
Hello fellow '8 owners I've been hanging around here for a while but have only just signed up. I've got a '98 S8 in volcano black pearl which I've had around a month now. Anyway I'm hoping someone can help me out with the pinouts for the instrument cluster on my car as despite a thorough search I've only been able to find the info for facelift cars.
Multi-pin connector -A- (26-pin - yellow) assignments
1 - Fuel level sensor signal
2 - Fuel level sensor Ground (GND)
3 - Door contact, driver's door
4 - Ignition key, terminal 86s
5 - Brake fluid level and hydraulic fluid level
6 - Seat belt switch
7 - Washer fluid level
8 - Parking light, right
9 - On board computer reset, left
10 - Board computer reset, right
11 - Board computer reset
12 - Temperature sensor Ground (GND)
13 - Fuel volume sensor (reserve)
14 - Outside air temperature sensor/ AC system
15 - Open
16 - Audio signal "On"
17 - Engine coolant temperature sensor signal
18 - Engine coolant level warning
19 - Brake light
20 - Backup light/low beam headlight
21 - Parking light, left
22 - Coolant fan third speed
23 - Engine oil temperature Ground (GND)
24 - Engine oil temperature
25 - Outside temperature sensor Ground (GND)
26 - A/C compressor "Off"
Multi-pin connector -B- (26-pin - red) assignments
1 - Trunk lid
2 - Door contact for driver's door
3 - Door contact, left rear
4 - Door contact, right rear
5 - Fuel level (for OBD II)
6 - Open
7 - Oil pressure 1.2 bar
8 - Open
9 - Transmission range indicator
10 - Open
11 - Auxiliary heater (remote control input)
12 - Hydraulic pressure
13 - Time signal as of ABS system 5.3 (open with ABS system 5.0)
14 - Open
15 - Open
16 - Open
17 - Summer/Winter
18 - RPM signal
19 - Fuel consumption signal
20 - Auxiliary heater
21 - Open
22 - Speedometer vehicle speed signal (output 2)
23 - Speedometer vehicle speed signal (output 1)
24 - Speedometer vehicle speed signal sensor signal (input)
25 - Brake pad wear indicator signal
26 - K-wire
Multi-pin connector -C- (26-pin - green) assignments
1 - Open
2 - Open
3 - Open
4 - Open
5 - Open
6 - Airbag
7 - ABS
8 - Door lock (output)
9 - Turn signal, left
10 - Open
11 - Open
12 - Open
13 - Open
14 - Open
15 - ASR
16 - OBD II
17 - Trailer turn signal lights
18 - Open
19 - High beam
20 - Parking brake warning light
21 - Generator (GEN) warning light
22 - Turn signal, right
23 - Open
24 - Open
25 - Airbag (active)
26 - ABS (Sila)
Multi-pin connector -D- (6-pin - white) assignments for voltage supply
1 - Terminal 30
2 - Terminal 31
3 - Illumination (3 W)
4 - Illumination for console (40 W)
5 - Terminal 58
6 - Terminal 15
Multi-pin connector -E- (4-pin) assignments for transmitter clock
1 - Transmitter clock signal
2 - Transmitter clock 5V
3 - Open
4 - Radio/Navigation clock ground
15 - Open
19 - Brake light
1 - Trunk lid
6 - Open
8 - Open
10 - Open
14 - Open
15 - Open
16 - Open
17 - Summer/Winter
18 - RPM signal
21 - Open
26 - K-wire
1 - Open
2 - Open
3 - Open
4 - Open
5 - Open
6 - Airbag
7 - ABS
10 - Open
11 - Open
12 - Open
13 - Open
14 - Open
15 - ASR
16 - OBD II
18 - Open
19 - High beam
23 - Open
24 - Open
26 - ABS (Sila)
1 - Terminal 30
2 - Terminal 31
5 - Terminal 58
6 - Terminal 15
3 - Open
Thanks, that was very quick. I'm exploring the possibility of using a 2nd VAG instrument cluster (I have a few lying around) with canbus to convert the relavent signals to send to the facelift climate panel. I needed the pin assignments so I could pick up the required signals. Odd's are it won't work but as I have the clcoks it'll only cost me time.
NAUDI4
05-27-2007 01:23 PM
