Sponsored by:
Sponsored by:
Car starts and dies
Old 10-01-2007, 10:32 AM
  #11
mpollan's Avatar
Anybody that can Overnight the other key to her. Would be cheaper no?
Old 10-01-2007, 11:10 AM
  #12
New Member
ymir's Avatar
Default If you've got an immobilizer: emergency start procedure and two alternative causes
If had starting problems with my A8 also. Symptom: with a previously known good working key: engine starts, but dies immediately, leaving the Check Engine Light on. After a few attempts the Check Engine Light (CEL) would flash and car would refuse to start altogether.
My emergency start procedure:
This probably only applies if you've got an immobilizer that refuses to accept a previously working key, but this is how I forced the engine to start:
(1) lock the door (remote or manual)
(2) unlock the door (remote or manual)
(3) start the engine giving it a lot of power. Just push the throttle halfway down.
It forces the immobilizer into some kind of emergency/bypass mode and it will run!
I don't know if its a official hack, but it did work on my A8. Also, not advised for everyday starting, but worth a try if it saves you the roundtrip....
Two alternative causes
Bad starting from a previously known good key could be any of these two:
1 - most probably: defective immobilizer wiring
Again if and only if you've got an immobiliser
see http://www.audipages.com/Tech_Articles/electrical_equipment/immowirereplace.html
2 - broken ignition switch
see http://www.audipages.com/Tech_Articles/electrical_equipment/ignswitchreplace.html
I actually had #1. My independent mechanic just sprayed contact spray on the whole immobilizer wiring assembly and it runs fine ever since.
Good luck!
Old 10-01-2007, 12:25 PM
  #13
Junior Member
ttuling's Avatar
Default If the gauges are not lighting up, hope that disconnecting the battery resets it
and if the gauges are lighting up and the immobilizer light eventually flashes, you might try removing and reinserting the key between each attempt to have the key recognized. You needn't crank the engine -- just turning on the key and waiting to see whether the immobilizer light goes out is enough.
Once the instrument cluster decides a key is bad and flashes the immobilizer light, it doesn't reread it until it's removed and reinserted (by experience with my car), and if the coil or connections are intermittent, it's worth trying a few more times.
If the problem is with the key or with the coil that communicates with the key and you have the four digit code, or the seven digit code plus dealer code, importer code, and date, you can use VAG-COM to log in and start the car despite the key not being recognized. Details in the service manual.
Tom
Old 10-01-2007, 12:59 PM
  #14
mpollan's Avatar
Default What is this 4 digit code of which you speak Tom? Is it the key code?
That is great stuff to know in a pinch.
Mark
Old 10-01-2007, 01:27 PM
  #15
tx170754's Avatar
Default Re: Anybody that can Overnight the other key to her. Would be cheaper no?
She is on her way, with one of our friends, to get the other key (90 miles one way) let's see if it works, otherwise she will ( again !) go back home ( needs to be at work tomorrow morning ) and I will to see what I can do.
Thanks everybody for you precious inputs, I will keep you posted, maybe we can learn something.
Old 10-01-2007, 03:12 PM
  #16
naid's Avatar
Default What's a reasonable price for programming the key?
The local dealer is asking $112. Makes me wonder since they are also asking $155 for the Navigation switch in the center console (4D0-919-721-B-01C) while the Audipages parts PDF lists it at $69.
Old 10-01-2007, 08:59 PM
  #17
Junior Member
ttuling's Avatar
The code you'd have used when setting up new keys to work with the immobilizer
Old 10-02-2007, 07:16 AM
  #18
mpollan's Avatar
Hmm, I never did that. Would the dealer who did my keys have it you suppose?
Old 10-02-2007, 07:16 PM
  #19
Junior Member
ttuling's Avatar
Not anymore, if ever they did. See the immobilizer question at www.ross-tech.com's FAQ
akingzkid
16
04-16-2023 09:51 AM
PFL1011
11-07-2008 07:07 PM
2PUTT
13
01-08-2006 12:55 PM
mech IFR
21
09-08-2003 09:12 AM
R Rodman
09-01-2002 04:23 PM
Quick Reply: Car starts and dies
