Carrier-to-Housing Bolt on Rear Calipers - Size and Type?
My rear calipers arrived today (for my 99' A8 pre-facelift) and, to my surprise they came complete with the caliper carrier brackets. So, I only need to undo the two large carrier-to-housing bolts in order to attach them. These bolts appear to be allen-key bolts. Does anyone happen to know the size, so I can go purchase the correct one? I fear that such a large size would not come in your run-of-the-mill set. Many Thanks - Michael
That is why I was hoping someone might come to my rescue with the information. But if need be I can operate a mirror and a flashlight simultaneously, I think. If they are "triple square bolts" I have no idea where to source the tool. (If I don't get any further replies I will have to get more investigative in the morning.) Thanks.
I have the "Lisle" set with about 8 sockets which you can find anywhere. I can dig up the bolts if you want.
Bob
Bob
Did one today, will do the other tomorrow. Incidentally, if you want to actually use an allen key, you will need a ball end, preferably with a handle. Otherwise, I recommend a 8mm allen bit.
mk4jetta
Audi Original "S" Cars
06-24-2010 06:07 PM
SereniTTy
03-22-2006 08:40 AM
what size are the bolts holding in the front calipers? Tech says 7mm hex, but they infact are larger
kkii9
05-01-2005 05:10 PM
NIIK TT
04-12-2002 07:50 AM
